Whilst the Web UI's Custom Forms and Views for each Object Type is useful, it's also very limiting presentation-wise if we want different users, computers, OUs etc. to have different forms/views based on group membership or other factors, it would be nice to have this so when ACLs are enforced for various object attributes that the users don't even see what they can't read.
An example might be we want Management users to be able to view Staff's many different user attributes but we don't want Management users seeing that same number of fields for other Management users etc. At the moment, we basically have to have different Web UI's and restrict login to them to each user group and then design the forms for the lowest common denominator in terms of access to information. I also don't think simply having the fields hide automatically if a user does not have read access to it is appropriate as we've often had to reshuffle fields into different sections for those users with more simplified interfaces.
Such functionality would allow us to streamline web UI configuration and allow us to properly use Adaxes as a web based self-service directory to our AD for all our various user groups and ensure a tidier experience whilst enforcing ACLs on various attributes and objects.
by (350 points)
Web Interfaces are dynamic and users can see only objects and properties they are allowed to see. You can configure Security Roles for users so that they see only what they need. For an example, have a look at the following tutorial: http://www.adaxes.com/tutorials_Delegat ... erties.htm.
There is no possibility to create custom view/modify forms for separate OUs. As a workaround, you can create View and Modify Object Home Page Actions with custom forms for each OU. For information on how to create the actions, have a look at the following tutorial: http://www.adaxes.com/tutorials_WebInte ... s.htm#view. You can find instructions for customizing the action form on step 4 of the tutorial.
asked Jan 17, 2023 by stevehalvorson (110 points)
Hi, I changed the view for user -> view and would like to copy those sections to modify ... but I cant find any option? Only copy it to other web interfaces?
asked Jun 5, 2023 by wintec01 (1.1k points)
Short Version: Issue: Found that the form\view config under /AdaxesConfig does not match what is seen on the user modify page Long version: We upgraded from 2017.1 to 2018 ... when editing a user are configured for the View Form for User in the /HelpDesk page
asked Sep 4, 2018 by jiambor (1.2k points)
good day, is there any chance to modify the behavior of the address field? Which displays a users address like this: We would like to have City and Zip/Postalcode comma ... question, can the blank line be removed from a drop down list? Regards Ingemar Jacob
asked Sep 16, 2013 by ijacob (960 points)
To the left of the user object there are several custom commands showing. I don't want our service desk to see them. Why are they showing? How do I remove them. Must be something simple. They only see these when looking at a user Object.
asked Jan 17 by mightycabal (1.0k points)
3,350 questions
545,074 users
