Hello!
We have an Business Rule that should enable the remote Mailbox after an User is created but that does not work. 2023-06-21_15h38_34.png
The Powershell Script that we have in an Custom Command does work because we have that set on the Webpage so that we can do it manually for now.
What can i do to make it work like we intend to?
Thanks in advance!
by (140 points)
The business rule triggers immediately after user creation unless there is a delay specifically added. As such, the second condition will never be met. To achieve the desired, just remove the condition from the business rule.
For some reason our Creating office 365 accounts has been failing to correctly mail-enable the users in our local exchange server - it builds it as a mail user ... ;domain>.mail.onmicrosoft.com Am I missing something in my business rule setup?
asked Dec 9, 2014 by danftasc (440 points)
Hi, we are running Adaxes in hybrid setup and on-prem as O365 is connected. My business rules looks like this Based on articles I have read here, the local mailbox should ... with a mailbox size of 2GB. Onprem: Online: Anything I am missing or misunderstood?
asked Jul 17, 2023 by wintec01 (1.1k points)
Hello, I have a sheduled task running. This task checks if a user is a member of a Licensed Office 365 Group with exchange online. If the user does not have an ... the on prem exchange mailbox and the exchange online mailbox? Thanks if you have an idea!
asked Feb 24, 2023 by fabian.p (150 points)
Hi We have Exchange set up in hybrid mode and are currently using scripts to create the remote mailbox. We're looking to enable Adaxes to do this (from here) but before we do ... there's anything special we need to do in order to get this to work? Thanks Matt
asked Jun 10, 2022 by chappers77 (2.0k points)
3,355 questions
7,799 comments
545,159 users
