We use TOPdesk as our ITSM solution. Several departments are able to create new users. When a create user task fails we would like to receive the alert as the Adaxes Administrators. What we would like to do is: or check the logfile every x minutes and when a error or warning is created fire a topdesk api powershell script to create an alert, or when an alert, error or warning is triggered we would like Adaxes to sent out the incident to our TOPdesk.
Is there a solution for this?
It can be done using a business rule triggering After creating a user. If the operation fails the rule will execute your script. The business rule will look like the following: image.png
This is for failed or suspended. Is this also for warnings?
This is only for failed. Suspended is dedicated to operations submitted for approval so there is no need to do anything in this case.
So no option for Warnings. Is a warning step a failed step in business rules?
The condition is met only if the operation itself fails. It does not depend on the actual reason.
asked Jun 30, 2021 by RayBilyk (230 points)
I am attempting to run a command using powershell. The command is using Google Apps Manager (GAM). Whenever the command runs and is successful, Powershell reports that it has ... . The issue lies with the software I am using and how it works with Powershell.
asked Nov 12, 2014 by mobosys (290 points)
Hi. I would like to know if there is way to send an email to HR once an account has been created or terminated by IT. The email should have the name of the user and there office location. Is this possible to be done?
asked Feb 7, 2020 by Satrai8 (20 points)
We are working with an HR package that will send us a CSV file every 4 hours with a list of users that need to be created, modified or deleted from our environment. The CSV ... change, etc.) Is there a script that can manage all of that on a scheduled basis?
asked Sep 2, 2020 by RayBilyk (230 points)
7,805 comments
545,184 users
