Hi, I need to retreive a secret from a Azure Keyvault in a business rule. I have a powershell script that works if i run a external command. But it fails if I run then same script in the "integrated" powershell environment. The start script are as follows
try { import-module az.keyvault
Connect-AzAccount -Identity
} catch { $context.logmessage($.Exception,"Error") throw $.Exception
When running it fails with:
Unable to acquire token for tenant 'organizations' with error 'Entry point was not found.'
Entry point was not found. Stack trace: at <ScriptBlock>, <No file>: line 20
Any sugestion? Kind regards Reidar Dick-Henriksen
Hello Reidar,
Unfortunately, this is a known issue with the Az.Accounts module and there is currently no workaround. In future releases, Adaxes is planned to support PowerShell 7 (recommended for the module) and it should work fine then. We apologize for the inconvenience.
Is it possible to disable then re-enable a Business Rule from a Scheduled Task? For example, when the Scheduled tasks starts, it disables a Business Rule, runs the Task(s), then re-enables the Business Rule when done.
asked May 11, 2016 by Kikaida (1.1k points)
Is there a way to set a users' UPN Suffix within a business rule (PS script)? I've seen the script to update the suffix based on OU, but our OU structure ... primary email address, or to apply a particular UPN suffix based on department. Either method works.
asked Apr 3, 2017 by steve.newton (50 points)
We are trying to extend our Adaxes management to O365 / Azure only user objects. Currently we use employee type to add traditional active directory accounts to business units and ... so, can this be used to create dynamic mail enabled security groups in O365?
asked May 3, 2022 by adaxes_user2 (40 points)
3,354 questions
7,796 comments
545,139 users
