This is the logic I ham useing.
$criteria = New-AdmCriteria -Type "User" -Expression {customAttributeBoolean6 -eq $true}
$usersC = Get-AdmUser -Filter $criteria -properties * -AdaxesService localhost What am I doing wrong or is there a better way to get the list of users into this variable?
by (1.0k points)
Unfortunately, there is no such possibility as Adaxes custom attributes cannot be used in search filters and criteria. The behavior is by design. As a solution, you can use the approach from this script: https://www.adaxes.com/script-repository/users-whose-adaxes-custom-attribute-is-not-empty-s43.htm.
We use this date to determin transfers and start dates. Basicaly on this day the Adaxes resets the password. In the report I would like to ... name, first name, last name, employeeID, CustomAttributeboolean1, customattributeboolean2, and customattributedate2.
asked May 17, 2023 by mightycabal (1.0k points)
asked Jan 19 by aweight (40 points)
Hello, We need a report or a custom command that export all Active Sync devices details. Is there a way to do it ? Thanks :-) Michel
asked Feb 11, 2022 by zemitch (200 points)
As the title says is it still a requirement?
asked Feb 23, 2023 by techg (320 points)
3,362 questions
7,812 comments
545,227 users
