We are looking for a way to allow AD users to manage group memberships of groups they have been set as Manager for - and would like to know if we can achieve this with Adaxes? We are thinking a easy to use web portal.
Hello nicolaj,
Yes, it is possible. For details on how to grant the permissions, have a look at section Grant rights to add or remove group members of the following tutorial: https://www.adaxes.com/help/GrantRightsToModifyGroupMembership/#assigned.
Rule-based membership fails for security enabled distribution group with error "The term 'Add-DistributionGroupMember' is not recognized as the name of a cmdlet, function, ... Exchange Online before running this PowerShell command. Here is rule based set up.
Hi, I'm trying to create a business rule that basically says if a user is a member of group a, they can't be a member of group b. Optionally would also like to ... removed from group a. Can i get some guidance on how I could accomplish this in adaxes?
We have a need to only allow users to groups based on employee type attribute. We have created a scheduled task today that scans AD every day at 9:00am and adds the ... like to stop the user from even be added outside of this task altogether. Any ideas?
I'm developing a Web interface to allow a user (or group of users) to add member(s) to or remove member(s) from one particular group. I've used Customize Operations to add ... of the group so that one or more can be selected to be removed. Is this possible?
