I've set it up using this tutorial https://www.adaxes.com/tutorials_Simpli ... Office.htm
It almost works perfectly on user creation, however the street portion never sets although it shows that it does.
Postal code, state/province, and city set as expected.
by (100 points)
Could you post here or send us (support[at]adaxes.com) screenshots of the Property Pattern and Custom Command (Business Rule or Scheduled Task) you have created?
Sent screenshots to support@addaxes.com
The correct email address of Adaxes support is support[at]adaxes.com. Make sure, you re-send the screenshots to it.
Sorry, sent it again!
by (273k points)
According to your screenshots, the Business Rule is configured correctly. Which property did you check after creating a user? As we can see the rule is updating the Street property (LDAP name street), not the Street Address one (LDAP name streetAddress).
Aha! Good catch, thank you!
This is for license purposes and we do not want them visible in the Adaxes portal.
asked Oct 22, 2021 by jfrederickwl (20 points)
In our organisation every department has a named manager. So if I add a new user and their department is "Sales" (selected from a property pattern) I have a business ... department. Any suggestions on the simplest way to achieve this would be great thanks :)
asked Feb 23, 2014 by hutchingsp (240 points)
Hi we are trying to add users to a group based on the values of their "Office" and "Description" attributes within Active Directory. We have populated the below ... $Context.LogMessage("No matching criteria found for User $($Context.TargetObject.Name).") }
asked Sep 18, 2023 by Loopy8822 (20 points)
I need a report that will show what O365 Licenses each user has based on Office. If can emailed or with in reports
asked Jan 17, 2020 by hgletifer (1.3k points)
Our Office 365 licenses are in a couple different SKU's E3, and E4 licenses. The E4 is an older set of licenses, and we purchased more and was assigned E3's. There are essentialy ... if the E3 licenses are all used, I'd like it to try to Assign the E4 instead.
asked Jun 30, 2017 by rurbaniak (1.4k points)
3,376 questions
7,822 comments
545,421 users
