There seems to be a bug in the email being sent to approvers - the link for the selfservice portal is not reflecting the change in the IIS configuration - it still points to /selfservice and not the new /Adaxes/selfservice URL
So when approvers recieve the email with the link to the selfservice portal they will get a 404 - File or Directory not found
by (500 points)
You need to update the Web Interface URL. For details, see https://www.adaxes.com/help/?HowDoI.Man ... rface.html.
Hi Just upgraded to 2018.1 Seems that backing up the web interface works differently than in 2017.2? How do I back up my web configuration now ? Thanks in advance!
asked Jul 4, 2018 by pafa (500 points)
After upgrading to 2018.1 I'm getting an error of "Your password must be changed before you can log in. The Change Password operation is disabled in the Web Interface." when ... my password. I cannot find the setting to enable this. Has anyone else seen this?
asked Jun 28, 2018 by jake_h (300 points)
When setting a default OU for new user creation, our domain does not expand. Editing users is fine, installed console is fine. Config was working before upgrade to 2018.1. Any suggestions?
asked Jul 17, 2018 by polley (1.2k points)
asked Jul 7, 2022 by Vish539 (310 points)
Hi, I was just wondering if there was a way to force the format of the date picker value in the web approval interface. We have operation that are very time specific ... like that in the web interface. Example of the problem: Thank you, Jean-Simon Tremblay
asked Dec 3, 2021 by jsimon.tremblay (20 points)
7,806 comments
545,206 users
