Hi
Just upgraded to 2018.1
Seems that backing up the web interface works differently than in 2017.2?
How do I back up my web configuration now ?
Thanks in advance!
by (500 points)
Starting from 2018.1 you don't need to back it up separately. Now Web Interface configuration is a part of Adaxes service configuration. The only tool you need to use is Softerra.Adaxes.BackupRestore.exe.
Ok - so I can only backup and restore the entire Adaxes configuration? (which of course is easier)
Yes
There seems to be a bug in the email being sent to approvers - the link for the selfservice portal is not reflecting the change in the IIS configuration - it still points ... the link to the selfservice portal they will get a 404 - File or Directory not found
asked Jul 4, 2018 by pafa (500 points)
After upgrading to 2018.1 I'm getting an error of "Your password must be changed before you can log in. The Change Password operation is disabled in the Web Interface." when ... my password. I cannot find the setting to enable this. Has anyone else seen this?
asked Jun 28, 2018 by jake_h (300 points)
When setting a default OU for new user creation, our domain does not expand. Editing users is fine, installed console is fine. Config was working before upgrade to 2018.1. Any suggestions?
asked Jul 17, 2018 by polley (1.2k points)
asked Jul 7, 2022 by Vish539 (310 points)
Hi Support, What Version of PowerShell does Adaxes 2018.1 support? Thx
asked Jun 22, 2018 by Napoleon (700 points)
3,362 questions
7,812 comments
545,232 users
