Is there a script we can use to take an OnPrem exchange mailbox and move it to Office365?
Adaxes version
2017.2
3.8.14823.0
Also is this something that is already part of 2018.1?
by (1.3k points)
by (273k points)
Yes, sure. For details, have a look at section Move mailbox to Office 365 of the following help article: https://www.adaxes.com/help/?HowDoI.Per ... mO365.html.
The same approach can be used in Adaxes 2018.1 and later.
That would work but we have 6 different OnPrem exchange servers that have different "mail.company,com" addresses. Is there a way to query which OnPrem server or database they are on 1st and then run the correct mailbox move command based on the result?
There is no need to query the addresses of your Exchange servers in the script. In the $remoteServer variable, you need to specify the complete domain name of an externally accessible on-premises Exchange server that has the Client Access role configured and the Mailbox Replication Service Proxy (MRSProxy) service running. For more details about the service, have a look at the following article by Microsoft: https://docs.microsoft.com/en-us/exchan ... -2013-help.
We have 6 different such addresses depending on which server a user's mailbox is housed on
Thank you for clarifying.
We have updated the script to meet your needs, find it below. You will not need to specify the name of the local Exchange server, it will be obtained by the script automatically.
# Get exchange server name
$homeDB = $Context.BindToObjectByDN("%homeMDB%")
$msExchOwningServerDN = $homeDB.Get("msExchOwningServer")
$msExchOwningServer = $Context.BindToObjectByDN($msExchOwningServerDN)
$remoteServer = $msExchOwningServer.DirectoryServer
$targetDeliveryDomain = "mycompany.mail.onmicrosoft.com"
$badItemLimit = "0"
$largeItemLimit = "0"
$Context.TargetObject.CreateMoveMailboxToO365Request($remoteServer, $targetDeliveryDomain, $badItemLimit, $largeItemLimit)
Is there a script we can use to take an OnPrem exchange mailbox and move it to Office365? Adaxes version 2017.2 3.8.14823.0 Also is this something that is already part of 2018.1?
asked Mar 12, 2019 by mytamhuyet (50 points)
I have setup a custom command to move a mailbox from on site to O365 using https://www.adaxes.com/help/?HowDoI.Per ... mO365.html and I'm getting the following error ... deatils OS: Windows server 2008 r2 Exchange: 2013 Adaxes details: 2017.2 3.8.14823.0
asked Jul 1, 2019 by hgletifer (1.3k points)
Is there a way to export mailboxes to individual PST files 180 days after the account was set to expire? /Kaj
asked Dec 5, 2017 by KajLehtinen (650 points)
Hello, currently we have an Exchange 2019 Server in Hybrid configuration with Exchange Online. During our user onboarding a mailbox for the user is being created by a ... Remote-Mailboxes in this scenario for newly created AD-Users? Thanks and KR Christian
asked Apr 18 by User0815 (40 points)
Hi, based on this article How to create Resource Mailboxes a few slide modifications aside we are currently creating resource and equipment mailboxes in our on-premise environment. ... to O365. Does this work at all? Appreciate your input. Kind Regards Ingemar
asked Oct 26, 2016 by ijacob (960 points)
3,372 questions
545,357 users
