The installation of the Adaxes software fails on my network. I have tried the installation on Multiple member servers.
All the servers are Windows 2008 R2.
The domain and Forest level is Windows 2008 R2
Error: Failed to create application partitions on the backend server.
Logon failure: unknown user name or bad password.
I tried installation using the Administrator account and also tried installing the software using a service account (domain admin). Both didn't work.
Ronnie
Hello Ronnie,
We didn't manage to reproduce such behavior in our testing environment.
In what format do you input the username during Adaxes installation? Can you try to install Adaxes under other credentials?
i tried both username@domain.local and domain\username
i did try 2 different account. Both admin.
Hello Ronnie,
Unfortunately, we didn't manage to reproduce similar behavior in our testing environment.
Please, have a look at the Event Log. Are there any errors or warnings related to the issue?
Also, try creating a new user with sufficient permissions to install Adaxes and try to install under the credentials of this user. See Grant Permissions to Publish Adaxes Service for permissions that a user requires to be able to install the Adaxes Service.
Hi, I need to retreive a secret from a Azure Keyvault in a business rule. I have a powershell script that works if i run a external command. But it fails if ... at <ScriptBlock>, <No file>: line 20 Any sugestion? Kind regards Reidar Dick-Henriksen
asked Dec 6, 2023 by reidardh (20 points)
Hi there, I can't seem to install the latest Adaxes client - an error appears - Error writing to file: Newtonsoft.Json.dll I've tried running the installer with admin rights but the same thing happens. Could you suggest anyway I can resolve this? Thanks, Henry
asked May 23, 2023 by henryg (20 points)
Rule-based membership fails for security enabled distribution group with error "The term 'Add-DistributionGroupMember' is not recognized as the name of a cmdlet, function, ... Exchange Online before running this PowerShell command. Here is rule based set up.
asked Mar 7, 2023 by KIT (910 points)
Hi We're testing Adaxes 2023 and I've found a small issue when connecting to AzureADPreview in a powershell script where it comeas back with the following: "One or ... account with Azure permissions. How can this be done with the app registration? Thanks Matt
asked Jan 16, 2023 by chappers77 (2.0k points)
Is the further clarification on how to join the Adaxes service to the configuration set during a multi-sever upgrade
asked Nov 16, 2022 by itsupport (20 points)
3,371 questions
545,353 users
