Hi
I've added values to two attributes of an Oraganization Unit:
adm-CustomAttributeText1
adm-CustomAttributeText2
I'm trying to extract these properties with a powershell script (this is to update the users email address based on a parent OU i a managed domain):
Import-Module Adaxes
$username = "user@domain.com"
$password = "password"
$domain = "domain.com"
$passwordSecure = ConvertTo-SecureString $password -AsPlainText -Force
$credential = New-Object System.Management.Automation.PSCredential ($username, $passwordSecure)
$User="CN=%fullname%,OU=Users,OU=%extensionAttribute1%,DC=domain,DC=com"
$email=Get-AdmObject -Credential $credential -Server $domain -Identity 'OU=%extensionAttribute1%,DC=domain,DC=com' | FL adm-CustomAttributeText1
Set-AdmUser -Identity $User -Credential $credential -EmailAddress %firstname%.%lastname%@$email -Server $domain
But this does not provide the value set in adm-CustomAttributeText1.
Any ideas?
by (960 points)
Can you describe in more detail what should the script do?
Also, are you trying to launch the script from Adaxes (with a Business Rule, Custom Command or Scheduled Task) or from the PowerShell console?
We are testing to see if Adaxes can be used in a multi-tennant solution. Therefore we want the user creation part to be "idiot-proof".
The script is put in a Business rule that launches after the user has been created. The script should then read the property adm-customAttributeText1 from the Customername ou (the user is created under Doman.local\Hosting\Customername\Users), and update the users email address to be %firstname%.%lastname%@ + the value of adm-customAttributeText1.
Here's the script that matches your requirements:
$ouDN = "OU=%extensionAttribute1%,DC=domain,DC=com" # TODO: modify me
# TODO: bind to the OU
    $ou = $Context.BindToObjectByDN($ouDN)
    $Context.LogMessage("$ouDN was not found", "Error") # TODO: Modify me
# Get domain part of the email from adm-CustomAttributeText1
    $emailDomainPart = $ou.Get("adm-CustomAttributeText1")
    $Context.LogMessage("The CustomAttributeText1 property of %extensionAttribute1% is empty", "Error") # TODO: Modify me
# Set Email property
$Context.TargetObject.Put("mail", "%firstname%.%lastname%@$emailDomainPart")
By the way, thank you for your interest in our product. :)
Fantastic! Script worked perfectly :)
I have to generate an Excel sheet populated with some users informations. It works on the server itself, but not when i run it via Custom commands. There is the code that ... it does'nt open and throws an error : How to interact with com objects on Adaxes?
asked Nov 29, 2021 by diaz801 (20 points)
asked Jan 19 by aweight (40 points)
Not sure if this is possible but is there a mechanism to query AD to get the latest "serialised" username. We don't use proper names for usernames we use a logon ... existing contractor logon name and create the next one in sequence. A bridge too far maybe?
asked Mar 4, 2015 by bistromath (840 points)
asked Mar 8, 2022 by Keonip (160 points)
7,805 comments
545,177 users
