Our techs need to be able to take ownership of the mailboxes when working in Adaxes? Currently, when a tech is looking in the properties of that user he doesn't have an option to take ownership of the mailbox. Help?
by (60 points)
At the moment it is impossible. This feature is in our TODO list.
If your technicians are advanced enough, they can edit the msExchMailboxSecurityDescriptor property manually.
Is there a time frame on when we can expect this feature to be added?
Not earlier than in three months.
Hi Eugene,
I'm really interested in these features. Can I get in some sort of mailing list to find out when you guys are ready to beta/deploy these new features?
In our company, we're using this product and the only portion we're missing is the one mentioned here.
A lot of our customers are waiting for this feature. We'll do our best to implement it as soon as possible.
You can subscribe to Softerra Adaxes news at http://www.adaxes.com/support_subscribe.htm
Hi Eugene,
Can you let me know if this feature will be added any time soon?
Thanks.
We are currently working on this feature. The functionality you need will be included in the next major release of Adaxes (September - October).
I have the HelpDesk web interface setup and I have a Create User task that our help desk can user to create new users. I have a Property Pattern setup that sets some ... it needs to be changed from what the default is. Hope that all makes sense. Thanks!
asked Apr 15, 2013 by bemho (520 points)
What permissions does a Trustee (Specifically a Manager or Owner) need over a Managed Object to make it visible in their My managed objects? The Trustee can view their ... missing read permissions of specific attributes, which are the minimum I need to allow?
asked Nov 2, 2023 by Viajaz (210 points)
At the moment we build an action that put users into a group until the specified End-datetime is arrived. Is it possible to specifiy a Start-Datetime, so the user will be ... group for a amount of time from day x to day y if needed for privileged actions.
asked Feb 6, 2023 by VinAx (50 points)
asked Jul 22, 2021 by jtop (680 points)
I need be able to select and export members of an AD group and export them to a CSV. Right now I can only seem to do 500. How do I increase that? Thanks, Tony
asked Nov 7, 2017 by cyspry (480 points)
3,365 questions
545,280 users
