Hi there,
Adaxes looks great. It needs a bit of time to investigate all the features.
I wonder how to upper lastname in a property pattern, to enforce strict naming convention.
Any clue ?
Thanks in advance
by (800 points)
At the moment, it is impossible to change the case of the values generated with the help of the value references.
In the new version, that is scheduled for April 7, 2011, it will be possible to do this. For example: %firstname:lower%%lastname:upper% .
Thanks for the information.
Any chance to have it in an intermediary build ?
I need to demo the product to my staff and i'm pretty sure that someone will challenge me on that point :-)
The build that contains the fix for the Exchange issue (Privileges in multiple domains environment) also contains this functionality.
Yesterday we released Adaxes 2011.1. This version allows changing the case of property values generated with the help of value references. For details, please see Changing the Case of Generated Values.
In your case you need to use the following pattern for the Full Name property: %firstname% %lastname:upper%
When we create a user account we need our domain user account identity values (email, logon name, and UPN logon name) to be in lower case. Currently, our email, logon name, ... are in upper case. Where do we make the change so that all letters are lowercase?
asked Apr 6, 2022 by Tfarmer (160 points)
Hello, I don't find an attribute for the netbios name of managed Domains like adm-DomainDN? How can I add the NetBios name to a report like "All users"? regards Helmut
asked Mar 5, 2021 by a423385 (510 points)
I have a need to pull the last n characters from a value and append it to another (adding last 4 of mobile number to sAMAccountName). I see the way to get the ... it will error out when trying to create it. Any advice would be greatly appreciated. Thanks!
asked Dec 20, 2017 by Bowman4864 (270 points)
Hello, I'm inserting a %datetime% value reference in the email notification action in a business rule. But the inserted time is UTC. How can I make it local time?
asked Jul 21, 2011 by sdd5533 (100 points)
Hello, is there a way to save powershell variable to axases attribute and send it via "send email notification" in Scheduled task? for example, check if Office 2016 ... .name) installed"} ` then add $customattrib value to Send email notification. Thank you
asked Feb 13, 2020 by vheper (20 points)
3,365 questions
545,275 users
