When we create a user account we need our domain user account identity values (email, logon name, and UPN logon name) to be in lower case. Currently, our email, logon name, and UPN logon name values are created in upper first initial of the first name and first letter of last name are in upper case. Where do we make the change so that all letters are lowercase?
by (160 points)
Most probably, that is the way you currently have your property patterns configured. For information on how to change the templates for property values generation, have a look at the following tutorial: https://www.adaxes.com/tutorials_SimplifyingDataEntry_ChangeTemplateForAutoGeneratingUsersFullName.htm. On step 2, right-click the property you need (e. g. Email).
Thanks, but the link you sent seems to be the link to my original question instead of the tutorial. Can you resend the link for the tutorial?
Sorry for the confusion, we updated the link in the answer.
Hi there, Adaxes looks great. It needs a bit of time to investigate all the features. I wonder how to upper lastname in a property pattern, to enforce strict naming convention. Any clue ? Thanks in advance
asked Mar 17, 2011 by sroux (800 points)
In user details or user details column, can we give visibility to our admins for SSPR Phone number and email used to do self-service pwd reset, and also the status. It can be through a report or available as a column.
asked Jan 4, 2023 by mchaudh (40 points)
This will run in a business rule "after creating a user" The email should be set to %firstname:lower%%lastname:lower%@mydomain. If the email isn't unique then it ... failure. This should update the emailaddress attribute in AD(not updating anything in Azure).
asked Feb 2, 2023 by mightycabal (1.0k points)
We are still using version 2017.2, because otherwise we can no longer authorize with smart cards. Is it still possible to connect Adaxes with Azur?
asked Oct 12, 2020 by Johann Ihnen (170 points)
3,365 questions
545,256 users
