I have looked over the customization instructions for the web interface but I didn't see how to do this...
Is is possible to replace the field names with something else? For example, I have a custom site for title managers to update only four or five fields. I want the field to display "Fax Number" but the AD name is Pager. Additionally, I use custom attribute 1 and 2 for signature elements, and I would prefer the field to display "Twitter Address" instead of Custom Attribute 1.
Is this possible?
by (470 points)
Yes, this is possible. Take a look at Customizing Display Names for AD Properties.
Perfect! Thank you.
I have created this file, since it didn't exist. I placed it in the suggested Adaxes 3 folder but I don't see the desired result.
What am I missing?
If you didn't find the file in the folder, then you were definitely looking the wrong place.
You need to edit the file on the computer where your Adaxes service is installed. If you have Adaxes Administration Console or Adaxes Web Interface installed on other computers, then you also need to edit the file on the computers where they are installed. The file is located in a system directory containing application data for all users in \Softerra\Adaxes 3 subfolder. Please remember that the path to the directory depend on the operating system and on the drive, to which Windows is installed.
I had a hunch that was true, so I did a search and couldn't find the file anywhere on the server.
The filename I seek was listed in your earlier post, http://www.adaxes.com/help/?HowDoI.Mana ... Names.html
Could the filename be different?
The file name cannot be different.
Please post the version of the operating system on the computer where Adaxes is installed and the path to the folder where you are searching for the file.
It's installed on a Windows Server 2008 R2 machine. I have searched the entire volume and haven't found the file.
C:\Program Files\Softerra\Adaxes 3 is the install path.
You should find it here
C:\ProgramData\Softerra\Adaxes 3
The default location for the all users profile
ALLUSERSPROFILE=C:\ProgramData
I got this figured out and found the file. The changes work as expected!
Hi, Can I change a field name in the Web Interface form? I want some fields to be displayed with other names than the attributes are actually called.
asked Jun 29, 2011 by jmirks (180 points)
Adaxes team, Have a functioning WebUI with basic config for each Interface Type, on IIS 6 / Win2003R2. These Interfaces are all on non-default Site in IIS, this particular IIS ... need to go through a special process to rename it so Adaxes "knows" about it?
asked Apr 10, 2015 by bradenmcg (260 points)
I read the article on using a business rule to automatically set certain field values such as address based on the value of the Office field. Is there any way to do ... on the Office field so the user has immediate feedback and can change it if necessary.
asked Aug 15, 2016 by jscovill (110 points)
Is there a way to edit the names of custom fields in forms? For example, I want to create a new field but my only option is use the name Extension Attribute 12. ... rename them within Adaxes so our help desk staff don't get confused when creating profiles.
asked Nov 20, 2018 by john.morrow (270 points)
asked 3 days ago by tromanko (260 points)
545,374 users
