hello-
We are utilizing the Helpdesk console and we're unable to add to groups. Access is denied.
I granted access for write member property on group objects as per doc, but getting access denied.
pls assist.
by (1.7k points)
The Access is denied error message means that, nevertheless, you didn't grant appropriate rights to manage the membership of the group. Can you post here or send us a screenshot of your Security Role, where the permissions and also the Assignment Scope of the Security Role would be visible?
wrong thread- disregard
is there a way to add a user to multiple groups at the same time?
Yes, this is possible. You can do this with the help of the Add to Group Home Page Action. For information on how to configure such a Home Page Action, take a look at the section called Add to Group in Configure Home Page Actions. In Step 4 of the section, you will find information on how to allow users to select multiple groups.
I am unable to install adaxes web feature on win 2016 server core, because the installer complains of web-mgmt-console feature missing. why is web-mgmt-console necessary ... server core. ps./ some roles are missing too: NetFx4-AdvSrvs and IIS-ManagementConsole
asked Aug 20, 2018 by pyrowing (50 points)
Hi team, I would like to add an action of having an input of Helpdesk Users, before adding someone to a group. I tried to create business rule, running "before ... very helpful: https://www.adaxes.com/questions/877/custom-scripts-user-input-at-running-time
asked 1 day ago by wintec01 (1.1k points)
asked May 9 by akindy (20 points)
I am looking for a way to make the Owners of groups review members in those groups every 6 months and approve\deny the members of said group. Flow would be something like this ... of the group. So if they didnt approve it, the user would no longer have access.
asked May 7 by ADuser (20 points)
We are looking for a way to allow AD users to manage group memberships of groups they have been set as Manager for - and would like to know if we can achieve this with Adaxes? We are thinking a easy to use web portal.
asked Apr 17 by Nicolaj Rasmussen (20 points)
545,386 users
