I have a business rule that fires when a new member or members get added to a specific group. Based on that, I'm trying to take those user objects just added, and perform specific steps on them. However, I can't figure out how to retrieve the user object DN or DN's of the users just added to perform those additional steps.
I seem to be fighting the limitation of business rule (group) to custom command (group). I need a rule to fire on a specific group membership addition, and then perform steps on those users.
I have tried doing this business rule on user objects, but I can't seem to get the rule to fire when I do it.
by (470 points)
by (470 points)
It took a lot of digging, but I found the way to do this.
The business rule is on the group, and the variable of interest is %member%.
From there, I have to execute a custom powershell command to execute the custom command that makes changes to the user object(s).
3,371 questions
545,356 users
