We have configured Self Service so users can reset or change their passwords.
But we disallow access to the account unlock feature through the Password Self-Service Policy settings.
How can I change the SelfPasswordReset page to eleminate the words "or unlock a locked out user account" ?
by (520 points)
edited by
Update 2018
Starting with version 2018.1 UI texts can be updated in the Web interface configurator. For details, have a look at the following help article: https://www.adaxes.com/help/ChangeUITexts.
Original
You can do this by modifying the Web Interface source files as follows:
  1. Open the folder that contains the Web Interface site that you want to configure. By default, Adaxes Web Interface sites are installed to the following folders:
    Administrators:
    Help Desk:
    Self-Service:
  2. Open subfolder App_GlobalResources.
  3. Locate file PasswordSelfServiceStrings.resx and open it in any text editor.
  4. Find the data XML element that has the name attribute set to SelfPasswordResetWizardDescription
     <data name="SelfPasswordResetWizardDescription" xml:space="preserve">
       <value>This wizard allows you to reset a forgotten password or unlock a locked out user account.<br>
     Please enter your user name and click Next.</value>
     </data>
  5. Change the text in the value element to whatever you need, for example:
       <value>With the help of this wizard you can reset your password.<br>
     </data>
  6. Save the file.
Please remember that these changes will not be backed up by Web Interface backup / restore. Thus, you will need to perform the changes each time you upgrade or reinstall Adaxes.
When allowing Account Unlocking from the Self Password Reset service, is there a way to limit the amount of times that someone can unlock their account before they are ... would be greyed out, or removed altogether). Is something like this possible? Thanks!
asked Jun 18, 2014 by PunkinDonuts (360 points)
We are looking to combine the password unlock/reset options to one screen and would like all information dispalyed only. ie. lastpassword set time, if account expires and so on. Thanks in advance for the help
asked Nov 9, 2016 by willy-wally (3.2k points)
Is there a way to combine the two functions for Unlock, and Password Reset? Most of the time, users lock themselves out because they don't remember the password, so the HelpDesk ... for the user, then changing the password. Is there any other way to do this?
asked Oct 24, 2016 by rurbaniak (1.4k points)
asked Apr 10 by awooten (60 points)
Hi, Is there any way to make Password Self Service Policies OR Operation? Let say, user can enroll to both Q&amp;A and OTP App Google Authenication. However, during the password reset, user can choose either to use Q&amp;A or OTP App.
545,392 users
