Hi, how can I change regex match to case sensitive in Custom Command conditions?
by (910 points)
In my initial question it should be: 'to be case sensitive', sorry.
It doesn't matter if I use [a-z]+ or [A-Z]+ in regex pattern, but it should. And I need to recognize if the letters in parameter are capital or not..
Live example is screenshot from my initial question.
For the condition to be met when the parameter value contains only uppercase letters, you need to use the following regular expression: (?-i)^[A-Z]*$
For lower case: (?-i)^[a-z]*$
For the condition to be met when the parameter value starts with a single capital letter followed by lowercase letters, use the following regular expression: (?-i)^[A-Z]{1}[a-z]*$
My situation is we give user's mailbox delagation without automapping somewhat randomly so in the web ui form we would like them to be able to select ad users in the input field
asked Jan 18, 2022 by Keonip (160 points)
asked Sep 15, 2022 by boris (470 points)
I am trying to use a property pattern to prevent email forwarding to accounts in other domains managed by Adaxes. Here is my regex: ^([^,]+,)+(DC=domain,DC=local) ... 't working? Is Adaxes using some other value before resolving the DN? Thanks in advance! Leah
asked May 9, 2019 by loliver (120 points)
3,362 questions
7,812 comments
545,230 users
