It's possible to integrate ADAXES with HR Solution to create user in active directory ?
reshown by
you can use PowerShell to get data from HRIS's SQL and let Adaxes do create/update user in AD.
by (11.4k points)
Out of the box, Adaxes does not integrate with third party software. However, if the HR solution you are using has an API, you can send requests from it to Adaxes using scripts.
Hello Adaxes support, can you send a link with instructions to integrate thrid party HR solutions? We have a thrid party HR solution for onboarding new employees that uses API. We would like to integrate it with Adaxes so that we can send requests to the thrid party software and have Adaxes create new user accounts.
Hello! Is there a way to clear the AD attribute "thumbnailPhoto" with a checkbox property? I wanted to implement a checkbox in the mask "Modify user" and if the box is checked, clear the attribute. How do I implement this? Much appreciated, Marco
asked Apr 21, 2022 by marco_jandl (60 points)
Can I manage the user that is user by Adaxes to connect to Active Directory with Privilege Access Management (PAM)? Since this user can change user's password, ... would like to manage this user so that PAM can change/rotate the password periodically
I've read this article; https://www.adaxes.com/tutorials_WebInterfaceCustomization_CustomizeHelpAndSupportLinks.htm?appView=1 However, it doesn't tell me how to add or remove columns from ... by the Quick Search. I'd like to add EmployeeId. thanks, Nate
asked Apr 10, 2022 by nate2 (90 points)
3,356 questions
7,799 comments
545,167 users
