I followed this example: https://www.adaxes.com/sdk/IAdmTop6.html, but because the Custom Command is disabled, I get the following error message:
System.Management.Automation.MethodInvocationException:
Exception calling "ExecuteCustomCommand" with "2" argument(s): "Custom command '<the name of the custom command>' is disabled."
---> System.InvalidOperationException: Custom command '<the name of the custom command>' is disabled.
at Softerra.Adaxes.Adsi.AdmObjectPipelined.ExecuteCustomCommand(String customCommandIdArg, IAdmCustomCommandArguments argumentsArg)
at CallSite.Target(Closure , CallSite , Object , Object , Object )
at System.Management.Automation.ExceptionHandlingOps.CheckActionPreference(FunctionContext funcContext, Exception exception)
at System.Management.Automation.Interpreter.ActionCallInstruction`2.Run(InterpretedFrame frame)
at System.Management.Automation.Interpreter.EnterTryCatchFinallyInstruction.Run(InterpretedFrame frame)
The Custom Command should not be available directly through the context menu, since it is meant to only be execuded by a script, another custom command, or some other form of automation.
For clarity, It works if I enable the Custom Command.
I am using Adaxes 2018.2
Best Regards Martin
by (100 points)
Hello Martin,
Unfortunately, it is not possible. Disabled Custom Commands can only be executed in Business Rules, Scheduled Tasks and other Custom Commands. As a solution, you can first enable the command in your script and then disable it after execution as in the below example.
# Bind to the Custom Command
$commandDN = "CN=My Command,CN=Custom Commands,CN=Configuration Objects,"+
    "CN=Adaxes Configuration,CN=Adaxes"
$command = $admService.OpenObject("Adaxes://$commandDN", $NULL, $NULL, 0)
# Enable Custom Command
$command.Disabled = $False
$command.SetInfo()
# Specify arguments for command execution
$commandArguments = $command.CreateArguments()
$commandArguments.SetParameterValue("MyParameter", "MyValue")
# Bind to the Organizational Unit
$containerDN = "OU=My OU,DC=domain,DC=com"
$container = $admService.OpenObject("Adaxes://$containerDN", $NULL, $NULL, 0)
# Execute the Custom Command for all users in the Organizational Unit
$container.Filter = @("user")
foreach ($user in $container)
    $user.ExecuteCustomCommand($command.CommandID, $commandArguments)
# Disable Custom Command
$command.Disabled = $True
$command.SetInfo()
Thank you for the quick reply, this solves my problem.
Is it possible to call execution of Adaxes custom command via SPML?
asked Oct 16, 2019 by Dmytro.Rudyi (920 points)
I have a dropdown-field on the web surface, which is populated by a script. The script looks up all groups in a specific OU and displays them. In the Property Pattern ... random order. What should i do to show the groups in alphabetical order in the portal?
asked Sep 15, 2020 by lohnag (160 points)
A little bit of context: There are 3 departments that share 1 Active Directory. Now each department has its own OU. I would like to have an email sent when a user is ... if this is possible without Powershell? If not, is there a pre-existing script for this?
asked Oct 3, 2023 by Cas (150 points)
We have a process that when a new user is created they are emailed their username and apssword. If the user is in an Admin Group they are then sent an email with some PDFs ... you can send emails, but am unable to see where it could attach files to the email?
asked Sep 3, 2020 by dknapp (100 points)
3,355 questions
7,799 comments
545,160 users
