Is it possible to call execution of Adaxes custom command via SPML?
by (920 points)
by (273k points)
Hello Dmytro,
asked Feb 19, 2020 by Martin (100 points)
Is it possible to send an email from Adaxes when certain AD objects are modified outside of Adaxes? With Business Rules it looks pretty easy to do that inside of Adaxes ... something changes on the object and the change was not initiated by Adaxes. Thank you.
asked Jul 23, 2021 by mikek (80 points)
Hello, I'm wondering if there is something like the calculated property "%adm-RandomString%", but that also includes symbols. Is there another command that accomplishes this task, or ... 's characters? Any way I could get this done within the realm of Adaxes?
asked Jul 7, 2022 by NKB#2772 (70 points)
3,371 questions
545,356 users
