I've got a few questions regarding the setup for the web interface and admin console in the DMZ found here.
  1. If we don't want the Admin Console accessible outside the network will leaving this internal affect this configuration at all?
  2. How is the Read Only Domain Controller being accessed by Adaxes in the DMZ?
  3. Would internal users also hit the RODC in the DMZ or would they use the internal DCs?
by (120 points)
No, you can only install the Web Interface component in the DMZ. There will be no effect on your internal Adaxes configuration.
The RODC is required to join the computer where Adaxes Web Interface will be installed to an AD domain. Additionally, it will be used by the Web Interface to obtain service connection points (SCPs) for Adaxes service. Operations will be performed through the Adaxes service installed internally which in its turn will connect to an internal DC.
Adaxes service will not have access to the RODC in the DMZ and thus it will always connect to one of the internal DCs. If you want, you can predefine the DCs to be used by Adaxes as described in the following help article: https://www.adaxes.com/help/?HowDoI.ManageActiveDirectory.ManageDomains.SpecifyDCsForDomain.html.
why is Adaxes component such as Adaxes Service and Adaxes Web Interface has to join domain?
what will the implication, if we deploy web interface in DMZ without RODC? (join domain to internal DC)
This is just how Adaxes works. It is a requirement for all Adaxes components.
The approach is not recommended as it will require opening additional ports to the internal DCs. For details about the ports used by Adaxes, see https://www.adaxes.com/questions/20/what-ports-does-adaxes-use.
We need your help, as we are trying to activate the license but we are not able to see that option. Please find the below screenshot for your reference.
asked Aug 24, 2022 by msharma2 (20 points)
When using the administration console (not the web console), we would like to be able to customize the fields that are shown on the different tabs of the user properties ... in the web interface but I don't see the same option for the administration console.
asked Jan 27, 2020 by abarker5 (80 points)
Hello, Currently, in LDAP browser of Administration Console, we can view only five columns in result search screen. Could you offer to view any attribute in future release? Thanks a lot for your response Yoann
asked Oct 4, 2012 by yoann.hamon (180 points)
Hi, We are currently still running an older version of Adaxes (2014.1) and having an issue with our 2nd server of Adaxes that is in our DMZ. I would like to resolve this ... done to the environment. I am wondering if I can get any assistance on this. Thanks,
asked Jun 6, 2017 by Kobe46 (390 points)
We have 4 om prem servers to setup Adaxes on, we currently have almost everything on one server but have crashed on several occassions when multiple scheduled jobs are ... way to achieve this configuration without having to buy double the licenses. Thanks' Jay
asked Sep 24, 2021 by willy-wally (3.2k points)
3,357 questions
7,801 comments
545,172 users
