Is it possible to use Property Patterns for Parameters in custom commands?
I would like to be able to restrict certain characters that users are inputting, especially since some of these parameters are used for logon names etc.
by (250 points)
by (273k points)
Hello, I'm trying to execute a custom command through a Powershell script, but I'm struggling to pass multiple values to an AD Object Picker parameter. ... , $NULL, $NULL, 0) $obj.ExecuteCustomCommand($command.CommandID, $commandArguments) Thanks in advance!
asked Nov 24, 2021 by KelseaIT (320 points)
I need to add many check-box list items to a Custom Command, I think the best way to do this is via PowerShell rather than through the UI. What's ... Softerra.Adaxes.Interop.Adsi.Parameters.IAdmParameterCheck[]]$ItemsList # Also doesn't work $command.SetInfo()
asked Jan 4 by Viajaz (210 points)
asked Mar 23, 2023 by mightycabal (1.0k points)
I would like to add a parameter for country to a custom command. Since the country has to be entered correctly in order for Active Directory to accept it, I would like to ... ? I didn't find it in the documentation and the sample scripts didn't use parameters.
asked Jun 4, 2020 by mark.it.admin (2.3k points)
Hi, I would like to use the custom commands to deprovision an AD user. Is there a way to automatically remove all groups (besides Domain Users which cannot be removed) from a user? Thanks...
asked May 1, 2014 by decop (20 points)
545,383 users
