Hi
I'm trying to find out the limit of entries in the textmultivalue custom attributes but am stuggling to find anything, Do you have any documentation on this?
by (2.0k points)
by (3.6k points)
We don’t have any special documentation about this, as the limit on the number of entries in multi-valued attributes comes from Active Directory, not from Adaxes. The actual limit is between 1200 and 1300 entries across all custom multi-valued attributes i.e. adm-CustomAttributeTextMultiValue1..10.
by (2.0k points)
Thanks for the response.
Just to confirm, that would be 120-130 per attribute?
by (3.6k points)
The total number of values is cumulative across all custom attributes. Thus, it can be 120-130 per attribute, or 1200-1300 in one attribute, while all other attributes are empty.
Hi, I am finding the SMS Settings options a little limited. We use a bispoke SMS web service gateway to integrate with our SMS provider and I have managed to use ... rather than in the query string or alternatively, to launch an external script or executable?
asked Feb 23, 2016 by sam.webster (410 points)
I have a custom adaxes attribute that I would like to utlitize in Rule Based groups; it does not look like they are available to select, however. Example: want something ... to group. Is this possible to make them visable in the Rule Based queries somehow?
asked May 28 by stevemkoenig (40 points)
Hello I am looking fro information on managing custom attributes in Adaxes. I would like to create two custom attributes: Self Service Enrollment Stauts Object Type While ... " column above is not a slectable attribute for some reason. Software version:
asked Dec 10, 2025 by apruitt (490 points)
