We are wanting to display all values entered into a multi value text attribute in an email sent by Adaxes.
What we've found is that only the first entry into the array will display when being referenced by a variable.
For example if adm-CustomAttributeTextMultiValue1 has four values
First Entry Second Entry Third Entry Fourth Entry
Any reference to %adm-CustomAttributeTextMultiValue% will always only display "First Entry"
Is there a way to reference the variable so that it displays all entries?
by (880 points)
Unfortunately, there is no such possibility using value references. To achieve the desired, you need to send the email using a script.
by (880 points)
Thanks for the information and I am not opposed to that. Can you provide the details on how the different values would be referenced and displayed in the script?
Have a look at the following script from our repository: https://www.adaxes.com/script-repository/get-multivalued-property-values-and-send-mail-s424.htm.
by (880 points)
Thank you
asked Jun 4, 2024 by KEME (150 points)
How do change the display name of a custom attribute in version 2017.2? All the information I am finding contains links that bring me to 2018 version
asked Nov 1, 2018 by hgletifer (1.3k points)
Before Deactivation of an Account on the Webinterface our Help Desk need to change the AD User Description manually. Is it possible to force a manual change before deactivation ?
asked Feb 7, 2020 by lv01 (20 points)
