Hallo,
In the deprovisioning process we add "_" to each email addresses like you see on below script:
# Get mailbox parameters
$mailboxParams = $Context.TargetObject.GetMailParameters()
# Change email adresses
$mailboxParams.EmailAddressPolicyEnabled = $False
$emailAddresses = $mailboxParams.EmailAddresses
for ($i = 0; $i -lt $emailAddresses.Count; $i++)
    $emailAddress = $emailAddresses.GetAddress($i,[ref]"ADS_PROPERTY_NONE")
    $emailAddress.Address = "_" + $emailAddress.Address
$mailboxParams.EmailAddresses = $emailAddresses
But sometimes we have user has X400 an X500 addresses we would like to remove those addresses, how can I do it using Adaxes SDK?
by (510 points)
Like this:
$prefixes = @("x400", "x500") # TODO: modify me
# Remove Address with the specified prefixes
foreach ($prefix in $prefixes)
    foreach ($emailAddress in $emailAddresses.GetAddressesByPrefix($prefix))
        $emailAddresses.Remove($emailAddress)
# Change email addresses
# Save changes
$Context.TargetObject.SetMailParameters($mailboxParams, "ADM_SET_EXCHANGE_PARAMS_FLAGS_NONE")
by (510 points)
And what if I'd like to change only SMTP addresses, without any changes on X500 and X400?
I mean we add "_" to all SMTP but left X400 and X500 without ant chanes.
Sure:
# Change SMTP email addresses
foreach ($emailAddress in $emailAddresses.GetAddressesByPrefix("SMTP"))
# Save changes
We have been able to add email addresses using the script in E-Mail Addresses Is there a way to reverse the process and specify the smtp address you want to remove using a similar subset of code.
asked Dec 14, 2022 by martin.mcclorey (40 points)
After creating a new user I'm modifying the user and setting 2 proxy addresses. I'm doing this with the build-in modify user functionality. Our email format is %firstname%. ... anybody have an idea to get this working, i'm not as Powershell wizzard...
asked Oct 15, 2018 by Quinten (100 points)
Hi, I need to create a number of mail user accounts via Adaxes and a lot of these accounts have & in the displayname/email address etc (I know, I know ... failed so I can troubleshoot it better. I have tried $context.logmessage($_.Exception.Message) Thanks
asked 2 days ago by RayBilyk (290 points)
Hi, would it be possible to script a workstation in AD and also directly from our local SCCM environment ?
