My question concerns the Self-Service web page.
I would like to know if there is a way to disable the Export and Print capability from the search results window? Self-Service.jpg
by (40 points)
You will need to disable displaying the Print and Export operations for search results. To do so:
  2. In the top left corner, select the Self-Service Web Interface.
  4. In the Operations section, select Export.
  5. On the Visibility tab on the right, clear the Search checkbox in the Visible column. image.png
  6. In the operations list, select Print.
  7. In the Grids section of the Visibility tab on the right, clear the Search checkbox in the Visible column. image.png
  8. Save the changes.
  9. Before checking the changes in Web Interface, refresh the page using Ctrl+F5.
By default, Web Interface URLs look like the following: http://host.company.com/Adaxes/HelpDesk. For the URLs not to contain the Adaxes part: On the computer where Adaxes ... C:\Program Files\Softerra\Adaxes 3\Web Interface by default. Click OK. Restart IIS.
asked Oct 30, 2019 by Adaxes (660 points)
We have a web portal on our ADAxes instance that we allow users to access, however this is not a self service portal and the users can only perform one task that ... not want to grant anymore permissions but I would like to remove this error. Thanks, Chris
asked Jan 16, 2018 by Bowman4864 (270 points)
asked Oct 10, 2025 by apruitt (560 points)
Is it possible to only allow a user to unlock their account from the web interface? We have a group of Mac users who we'd like to be able to unlock their accounts through the web but use a different service for changing their passwords.
asked Jun 30, 2020 by scoutcor (180 points)
