we manage 20 Domains with Adaxes. How can we create a Business Unit that holds all objects within OU's /Builtin and Users of all managed Domains without adding each OU seperately?
regards Helmut
by (510 points)
Hello Helmut,
As LDAP filters do not allow wildcards for DN-syntax attributes, there is no possibility to specify all the Organizational Units (OUs) using a wildcard in a single membership rule. You should add each OU to the Business Unit via a separate membership rule.
What would be the best way to create a Business Unit for all users in a domain that have Office 365 licenses assigned to them? I can do it with powershell but I would like to have the Info as a Business Unit and I don't want to re-invent the wheel. Thanks, Tim
asked Jun 20, 2017 by timskag (150 points)
I have applied a security role to a group at the top of a Business Unit Container and set it to apply to the subtree and it does, all Containers and Business Units do ... Unit. Did I apply the permissions wrong or is there some setting I need to change?
asked Aug 9, 2024 by ajmilic (130 points)
New to Adaxes and I'm working on creating Business Units. However, I noticed that when I create a new BU and select all objects in an OU for users, not ... Domain Admin. Any help with understanding why this is occurring would be greatly appreciated. Thanks!
asked Sep 18, 2014 by GeorgeM (100 points)
