is it possible to change the language for the admin console only from german to english? The Webinterface must not be affected.
Best regards
Manuel
by (90 points)
If the Web Interface and Administration Console are installed on one and the same computer, then it is impossible.
by (90 points)
Hi Eugene,
okay, thank you for the quick answer.
But now we have an other problem, maybe you can help us with that.
I set a pattern for initial passwords, but everytime we create a user, this warning appears: "The password wasn`t set because of the following error: The user name could not be found".
Do you know something about this problem? How can we fix it?
Best regards
Manuel
Hello Manuel,
Does the error occur when you specify a password manually?
This error can occur if there are multiple domain controllers in your environment, and SSL is not configured for some of them.
This is a well-known issue and it will be fixed in 2011.3 release (that is scheduled for November, 14).
For now I suggest you enable SSL on all domain controllers.
by (90 points)
Hi Eugene,
thank you very much for the fast answer, we will fix that.
Best regards
Manuel
Hi everyone! We are currently evaluating Adaxes, and I have a question concerning the admin console language. On my laptop, where I installed only the AC, it currently ... get rid of the language mix and display everything in English? Thanks for your help!
asked Nov 14, 2019 by EirĂ­kr (120 points)
After following the process outlined at https://www.adaxes.com/help/ConfigureMailSettings/#exchange-app-auth, I enter in the smtp server, port 587, the server requires ... nothing. Checked the adaxes logging, nothing. Any help is apprecaited. Thank you!
asked Jul 10, 2025 by emeisner (180 points)
In the Adaxes Administration Console, when I try to add a specific user to either "Administrators" or any Security Role, the Select dialogue box can't find it. I ... console can find without issue and all the permissions on the user object are the same.
asked Jun 4, 2025 by jmatthews (250 points)
Hello, Is there a way I can make the Desktop Adaxes Admin Console Dark Themed? I know how to on the Web Interface, but wondered for the full console. Thanks!
asked Nov 19, 2023 by Edogstraus00 (590 points)
Hi, I'd like to install the admin console on my Windows 10 22H2 Azure Joined computer. Product Version = 3.16.21515.0 2023.2 I get the following error when I run ... install Softerra Adaxes 2023.2, this computer must be a member of an Active Direcoty Domain. I
asked Jul 13, 2023 by KevC (60 points)
