Is there a way to have attributes display as a hyperlink within the web interface similar to how the "Web Page" attribute works? It really could be any attribute so long as the label could be modified to say something else, such as "Office Map". As a bonus, it would be ideal if the attribute could be parsed so that other text in the attribute could be added that is not hyperlinked, e.g. "Room206 - http://map/factory.pdf". This currently doesn't work with the web page attribute. Lastly, this could serve as a feature request to add some kind of a mapping/location functionality to Adaxes.
by (540 points)
No, currently this can't be done, but thanks for the suggestion. We'll think on that.
by (580 points)
Hi there
Was this ever implemeted? I am working on something that I would love to be able to apply this to.
Unfortunately, there is no such functionality in Adaxes. However, we will pass the update to the corresponding department.
I have Search configured for one of our web interfaces. One of the fields that can be searched is a custom attribute admCustomAttributeText4 (with a friendly name of ... are definitely some accounts with that attribute populated. Is this behaving as designed?
asked Sep 19, 2018 by sandramnc (870 points)
Hello, I have published Adaxes Console in Citrix XenApp (Windows 2016 Servers) and since (not sure about it) the last Windows update the search result doesnt display any object ... not have the issue with the locally adaxes console on Window 10. Any idea???
asked May 16, 2018 by tentaal (1.1k points)
asked Jul 8 by lbressan (140 points)
