After search a little bit on the forum, I thought I should be able to use jpegPhoto and thumbnailPhoto using Adaxes.
However, I have been unable to load a photo into the jpegPhoto attribute successfully. Any guidance on this?
by (1.2k points)
Currently, it is impossible to load a photo into the jpegPhoto attribute via the Web Interface. In the next major version of Adaxes, we a re going to improve handling of photos in Adaxes, including the possibility to use more attributes for photos than just thumbnailPhoto.
Until the new version is available, you can update the jpegPhoto attribute using a script. For example, you can create a script that will load a photo for a user from a certain file share. Then, you can create a Custom Command that can be used in Adaxes to run the script on a particular user. If you need, we can provide you a script sample.
by (1.2k points)
It would be awesome if auto-cropping for square headshots could be integrated, check out this powershell example: http://www.myskypelab.com/2015/02/photo ... iness.html .
That way, someone could upload whatever size photo (config permitting) and the software would attempt an auto crop and resize.
Trying to get people to crop 1:1 before uploading pictures is near impossible. ;)
When we create a shared mailbox, we create an associated mail-enabled security group. In the security group I want to populate the description field with the name of the shared mailbox ... How can I get just the "name" of the shared mailbox versus the full DN?
asked Feb 4, 2021 by atnorman (120 points)
I've got a scheduled agent that is attempting to export data for updated employees. When an employee record is updated, we're setting the value of the LDAP custom attribute ... ") # Release resources used by the search $userResult.Dispose() return } ...
asked Oct 17, 2015 by sandramnc (870 points)
When someone is using a Custom Command, can you detect (WIth PowerShell as Action) "who initiated" the Custom Command? I found that you can use e.g.: adm- ... that are available or are only the %Adm-InitiatorFullname%; ...EMail; ...Dn available?
asked May 12 by LorenzR (40 points)
We need to have a process to revoke the access token used by Okta for end users.
asked Jan 22 by william.malone (100 points)
I need to connect to Exchange Online using specific service principal, but I am getting error I am trying to authenticate via Connect-ExchangeOnline -AccessToken $token - ... btw aka 3.8.0 version of the ExchangeOnlineManagement module is used automatically.
asked Nov 18, 2025 by KIT (1.1k points)
