The section is not defined in the available options in Adaxes and it is in the AD as well. Eg; I need to add a section called ' Security Access' and have it include a drop down list just to select from options like User Directory, Internet access, Track-It account , SAP access etc.
by (40 points)
Hello Aishwarya,
You will need to take the following steps:
  1. Make an input field for a specific property a drop-down list: https://www.adaxes.com/tutorials_SimplifyingDataEntry_MakeInputFieldDropDownList.htm. For example, you can use one of Adaxes custom attributes (e.g. CustomAttributeText1).
  2. Add the property to the required Web interface forms: https://www.adaxes.com/tutorials_WebInterfaceCustomization_CustomizeFormsForUserCreationAndEditing.htm.
If this is not what you need, please, describe the desired behavior in all the possible details with live examples. Screenshots will be very helpful. You can post them here or email at support@adaxes.com.
Hello, We are trying to accomplish supplying multiple "office" entires into AD from the create user form. We have employees that belong to multiple physical offices. Is ... the form and also select multiple offices for an employee. Thanks for your assistance!
asked Oct 26, 2020 by sgordon213 (110 points)
