Hi Support,
how do I check if extensionAttribute9 was filled in (regardless of its value) when employeeType (which in our case is a dropdown with different values) is set to Consultant before creating a user object and Cancel the operation / creation with some sort of remark to the initiator if it wasn't?
kind regards
Ingemar
by (960 points)
never mind, found something that worked for me
Form Fun
kind regards
Ingemar
We are looking for a tool that can support a blacklist for password resets and that will enforce this blacklist to certain OU groups but not others, or potentially use a whitelist of users that it will not be enforced upon.
asked Mar 2, 2020 by zachThankYou (20 points)
Unfortunately, the logon names are not set automatically when a user is created. For the Full Name attribute everything is working fine. Where did I make a mistake here? Greetings, Robin
asked Apr 26, 2022 by robin.christmann (160 points)
I am looking for a way to ensure that a custom command can only be run is an user account is more than 30 minute old. Ideally I would like the command to be hidden ... is less than 30 minutes old. We need this check because of sync timings. Thanks, Allistair
asked Dec 18, 2023 by a.blonk (190 points)
Good Afternoon, I have been looking through the forums and I might have missed it, but here's what I'm looking to do I currently have a business rule that is being ... another set of different conditions. Let me know if I need to explain my request further.
asked May 12, 2014 by jtop (700 points)
Hi, is it possible to combine conditions with AND and OR in one action? For example: if the Operation succeeded AND the 'Department' property equals 'Marketing' OR the 'CustomAttributeText1' equals 'Yes' then Action thank you in advance, Napoleon
asked Jul 4, 2013 by Napoleon (700 points)
550,366 users
