Good morning,
I'm trying to process a search and export using the Adaxes console to create a list of users using specific criteria. I've been able to process this before but now when I try to export I receive the following error and the job is cancelled
Please advise on how I might proceed in addressing this issue.
by (720 points)
by (16.8k points)
For troubleshooting purposes, please, provide us with all the steps you take to reproduce the error. Screenshots would be much appreciated. You can post them here or send us at support@adaxes.com. If any filters are used in the criteria, please, provide them in text format.
by (720 points)
the only filter I apply is using a custom property "Employee IF is not empty"
When I process the export I only select the following properties:
Employee ID First Name Last Name Full Name Job Title
This query returns 585 objects, fetched the data then shows it as being cancelled. I was able to get this to process in the past, not sure what the difference is this time.
by (16.8k points)
For further troubleshooting, please, post here or send us at support@adaxes.com screenshots of each step of the Export Data wizard. On step 3 of the wizard, copy the search filter you are using and provide it in the TXT format. image.png
Additionally, please, specify your Adaxes service version. For information on how to check it, have a look at the following help article: https://www.adaxes.com/help/CheckServiceVersion.
by (720 points)
Service Version : 3.14.18802.0
Below is the steps I'm taking to process this export:
I then select all the users located with this search and select Export
It then processes the command fetches all the data, then fails.
by (16.8k points)
Thank you for the provided details. Unfortunately, we are not able to reproduce the behavior. For further troubleshooting, please, specify the following:
  • Is Microsoft Excel installed on the computer where Adaxes service runs?
  • Please, try to export several users out of 585 found users. Do you face the error in this case?
  • Do you face the error if you specify the CSV export file format on step 1 of the Export Data wizard?
by (720 points)
so I'm able to process this with a .csv
There is no office installed on this server, does the office suite need to be installed for this functionality to work to a .xlsx
by (16.8k points)
Thank you for specifying. Yes, to be able to export to XLSX format, Microsoft Excel must be installed on the computer where the Adaxes Administration console runs.
Hello, I am scripting user creation. I have created a custom command where an end user will submit info for the user to be created from: Here is the scirpt: # Import the ... Schema. I have tried using "Employee Type" as in the screen shot above but same error.
asked Apr 6, 2023 by mightycabal (1.2k points)
Our Adaxes Microsoft 365 Tenant was created before we copmpleted the "app registration" in Azure. Which means that in the instructions for "Register Adaxes as an app in ... M365 tenant, would that affect any of our custom commands that we have created?
asked Feb 17, 2022 by Tfarmer (160 points)
I've been attempting to run the "Management History" report located in Reports -> All Reports -> Miscellaneous->Logging based on this script in the repository. ... to using the ADSI Adaxes functionality and I'm not sure where to begin troubleshooting.
asked Aug 15, 2023 by awooten (100 points)
As title indicates, searching or browsing a group doesnt show its members. However, when I choose a modify group function, for that same logged in user, the group members ... or explicit filters to viewing members that I can see. What could be causing this?
asked Nov 2, 2021 by manomano (80 points)
