I'm searching the best way to trigger a business rule after the execution of an action.
The action will allow user to edit some of their attribute (but not all) and i was wondering how i should set the business rule to apply each time the action pane is used.
by (460 points)
by (460 points)
Any idea to help me ?
by (2.6k points)
Hello
Business Rules triggers before and/or after creating, manipulating and/or deleting an AD object.
What are you trying to obtain from your action ?
- Cheers
by (460 points)
In my company there is a process called "Mobility" where user "move".
Which can result in : OU modification AND/OR department modification AND/OR Manager modification.
So i create an action with a form where they can change those parameters.
Now i'm searching the good business rule trigger to launch my script when user fill the Mobility process form.
by (2.6k points)
Hello
In this example, I check a custom attribute for changes and if it has changed to "True".
The custom attribute are linked to a checkbox on my form.
You can do the same with all properties you use on your form.
- Hope this helps you.
Then I could put the approval on the custom command.
asked Dec 4, 2023 by mightycabal (1.2k points)
I am trying to get the script from the link below working, but it's not producing any results. I copied the two column IDs, and I adjusted the param-Date ... the script: https://www.adaxes.com/script-repository/recently-enabled-users-with-initiator-s681.htm
asked Nov 27, 2024 by apruitt (430 points)
Hi, if a user creates a new user via web form and backend scripts are executed, is there a way to skip this waiting page? I not sure if I found some setting in the ... asynchronously" would do the trick, no? But I want all task are excuted one after one.
asked Jan 24, 2024 by wintec01 (2.5k points)
