What is the easiest way to reset the license calculation for ADAXES back to say a new installation?
We've unmanaged (manually) a number of accounts and we'd like to add these accounts back in so ADAXES can manage them.
I see no obvious button or script anywhere that would allow us to simply "start over" in terms of licensing.
Thanks in advance.
by (610 points)
If the user accounts were added manually, the easiest way would be to remove them using the built in user interface. To do this:
  2. Right-click your Adaxes service.
  4. In the Licensing section, click Restrict.
  5. Right-click any user and pick Select All.
  6. Click Remove.
  7. Click Yes, then click Apply.
by (610 points)
I completed missed the "Add..." button. What I wanted to do is re-add all available accounts to be managed by ADAXES as many were manually removed. Thank you for helping me see what was right in front of my face :)
Hi all, Just wondering when Adaxes actually determines the current unmanaged/managed user counts - is it random, scheduled, or a manual thing? Also, does it randomly re-determine ... the script ran successfully every night, so I am not sure here. Cheers all.
asked Sep 22, 2020 by TheLexicon (200 points)
I am wondering what the expected behavior is, and what troubleshooting can be done, for this issue: We have a few tenants listed under Cloud Services > Office 365 We ... know, but they don't have access to force the license update themselves. Thanks, Jason
asked Jan 9, 2019 by Jasonmh (540 points)
I have a few questions on licensing. Which accounts are excluded from the license count? I understand you can exclude users, by OU possibly. I'm more interested ... . What happens during license validation? What happens if you go over license count?
asked Jul 2, 2020 by ComputerHabit (810 points)
hello, We are doing poc for Adaxes software. Our need: Adaxes as front end to manage multiple isolated domains with no trust e.g. Domain A, Domain B. We deployed ... domain B always gives error "User or password is not correct". Is this toplogy supported
asked Jul 11, 2024 by VBahubali (40 points)
Hi, We are currently considering spinning up a test environment for our Active Directory infrastructure, which includes Adaxes. Can we use our existing Adaxes ... the licensing requirements for test/development environments? Thank you for your assistance.
asked Sep 11, 2025 by wintec01 (2.5k points)
