I used the script below to try and accomplish this but I get an error. I did try to leave a comment but it would not let me.
I tried running the first example and I get
Exception calling "BindToObjectByDN" with "1" arguments: "Cannot parse ADsPath string." Stack trace: at GetUserSids, : line 13 at ,: line 13
Here is the two OU's I added to the first line: OU=05 - Service Users,DC=example,DC=local CN=Users,DC=example,DC=local
https://www.adaxes.com/script-repository/add-users-located-in-particular-organizational-units-to-unmanaged-accounts-s178.htm
by (210 points)
by (210 points)
Was able to fix it by adding all OU's inside the " 05 - service users" OU
by (3.6k points)
Hello Raul,
Probably the issue occurred because you have specified the value of the $ouDNs variable in the script incorrectly. It has to be an array of distinguished names of Organizational Units like so:
$ouDNs = @(
    "OU=05 - Service Users,DC=example,DC=local",
    "CN=Users,DC=example,DC=local"
We just busted our licence limit of 400, but we are only 320 employees. All the extras are either service accounts, external contractors accounts or old user accounts ... is reinstated on the 'managed accounts' list? Thank you for the guidance, Louis
asked Apr 11, 2022 by lw.fa (150 points)
I need to add many check-box list items to a Custom Command, I think the best way to do this is via PowerShell rather than through the UI. What's ... Softerra.Adaxes.Interop.Adsi.Parameters.IAdmParameterCheck[]]$ItemsList # Also doesn't work $command.SetInfo()
asked Jan 4, 2024 by Viajaz (210 points)
Are PowerShell commands supposed to show up in the programming interface after adding the module to the Adaxes server? I've installed modules and they don't show.
asked Aug 4 by Lucian (20 points)
asked Jan 27, 2023 by samuel.anim-addo (20 points)
