We have users with a value of a space for their mobile number and telephone number. I would like to figure out who these users are and null the value. Or if the value contains a number leave it alone. if it does not have a number then null the value.
by (40 points)
by (3.6k points)
To do this, you can use a scheduled task for the User object type, configured to run only once. For example: image.png
The mobile and telephone numbers should be cleared with the Update the user actions in the scheduled task: image.png To clear the numbers only if the current value is a space, you need to use the If <property> <relation> <value> condition and specify If - Telephone Number - equals -   in the condition parameters like so: image.png Alternatively, you can select If - Telephone Number - matches regexp and specify a regular expression which the property values should match to become cleared.
The scheduled task should be assigned over All objects or over Organizational Units / domains where you would like to look for users with spaces in phone numbers. For more details about creating scheduled tasks, have a look at this tutorial.
Hello All, I would like to update the property "Home Directory" from it's current value, to a new value. Right now it's referencing %username% and I would like to ... need. I just need this value generated when the user is created. I appreciate any help.
asked May 26 by SteveCDSAZ (20 points)
asked 1 day ago by cllano (20 points)
When i want to register a new Managed Domain, i get an error: Unavailable Domain. An error occured when connectiong to domain '...'. The Server is not operational.
asked Mar 19 by IDKOM (40 points)
550,365 users
