Salutations,
We have an Adaxes server that we use that was setup by someone whom is no longer with us. There is a section in the web interface that a standard user uses that has an extra input field randomly in the form which is preventing executing the action PS1 script properly. The docs mention a "Web Interface Component" that should be used, but I just see Adaxes Console and Adaxes PowerShell Module. I checked the Powershell Module for something that may help but came up empty.
I just need to remove an input field from a form that standard users fill out on one of the web pages Adaxes has setup in IIS. Suggestions?
by (16.7k points)
Adaxes Web interface is configured via the Web interface configurator. By default, it is available by the link like this:
http://host.domain.com/AdaxesConfig
Where host.domain.com is the FQDN of the computer where the Adaxes Web interface component is installed. Unfortunately, there is no easy way to determine on which computer in your environment the Web interface component with the Web interface configurator is installed. You can try checking Windows Programs and Features on computers to see where the Softerra Adaxes components are installed. Then, check IIS on these computers to verify if there are websites hosting the AdaxesConfig application present.
Once you find the Web interface configurator, you can use it to configure the required form in the required Web interface. For details on how to modify forms, have a look at the following tutorial: https://www.adaxes.com/help/CustomizeFormsForUserCreationAndEditing.
I have a web view set up where the user is locked down to only seeing thier approvals. When they get a email notification, and click on the approve or deny link, ... that would grant this access but I am wondering if there is something I am missing.
asked Apr 7, 2023 by mightycabal (1.2k points)
asked Jul 7, 2022 by Vish539 (500 points)
Changing the "Forgot your password?" text.
asked Mar 10, 2020 by msylvester (60 points)
Hello again! I'm building a script that will create Adaxes Security Roles for each new customer we bring on I'm trying to create a Role with the ability to change ... properties for user or group objects it would really help me get the script finished up.
asked Nov 14, 2015 by drew.tittle (810 points)
