Hello!
As part of my onboarding routine, I have a custom form that has a Boolean value for send welcome email to employee. I also have an optional field for personal e-mail address. Is it possible to ensure if the person selects send welcome e-mail the personal email field becomes mandatory?
If not is the best method using a business rule check before creating the user?
by (220 points)
Unfortunately, there is no such possibility. However, we have the feature in our TODO list.
Yes, that is correct. The business rule will look like the following:
If I buy 2026.1 today without AMS, is there any support/major updates included for a limited time, i.e. some sort of free AMS for 30 days after the purchase? Similarly, are ... also buy AMS at a later date (assuming you're on the current version)? Thanks, TJ
asked 1 day ago by TJ (20 points)
Hi, I am trying to clear the manager of disabled accounts and created a scheduled task for this Right now it is failing for all users (currently 4 in total) With error ... but it won't also remove/clear the manager. All user still have the attribute set.
asked Jan 30, 2024 by wintec01 (2.7k points)
asked Aug 15, 2025 by cllano (30 points)
