I am trying to set forwarding for a shared mailbox to a contact.
Adaxes is not able to find any contact? I tried to search by name and then selected OU itself, but no objects found. image.png
Best Christian
by (2.2k points)
by (306k points)
Hello, This was a known issue in Adaxes. It was fixed in the latest update for version 2023.2.
What’s New
Upgrade instructions
by (2.2k points)
Update 3 was missing - will install it now :)
Hello, I've got strange issue. I cannot use mail contact to forward emails to from 365 mailbox. I get this error: We are in Hybrid exchange. Mail contacts are ... be successfully done in Exchange Online, but not through Adaxes. Where the issue might be?
asked May 6, 2019 by DLe (760 points)
asked Jun 19 by scoutcor (180 points)
Hello, I'm working on an enable user option that does the following 1) Enables the user 2) Admin can manually adjust the Description of the user. 3) Moves the user to a ... them all and just want to make sure I select the correct attribute if it is one.
asked Jan 19, 2016 by jtop (720 points)
Dear support, We are trying to achieve a situation where a user will be able to do the following: Create a mail enabled Office 365 contact. Add this office 365 contact to a ... . Hopefully you can help me on this quest. Thanks a lot and kind regards, Remco.
asked Feb 11, 2021 by remcobraspenning (20 points)
