Hi team,
currently the loading of "My managed objects" is timing out for some users after exact 1 minute with error image.png
I assume its because of so many AD objects needs to be checked and some users have access to 20+ groups.
Can I increase this timeout or speed up loading in backend?
Will this also be cached in current browser session? I see for other users each time I open homepage its loading again and again and take some times.
by (2.4k points)
by (16.3k points)
There is no such timeout in Adaxes itself. Most probably, you are using a load balancer or a proxy server that has the timeout set for 60 seconds. Additionally, in the latest Adaxes version (2023.2 Update 3, build number 3.16.21906) we improved the performance when generating the My managed objects content pane on the Web interface home page. For details, have a look at the corresponding section of the following What’s New article: https://www.adaxes.com/info_whats-new_2023.2.htm#update3. If you are using an earlier version of Adaxes, we suggest considering the possibility of an upgrade. For information on how to check your Adaxes service version, have a look at the following help article: https://www.adaxes.com/help/CheckServiceVersion. For upgrade instructions, have a look at the corresponding section of the installation guide: https://www.adaxes.com/help/InstallationGuide/#upgrade. Also, if you have charts on the home screen, you can consider disabling them, which will also increase the overall performance of the Web interface home page. For information on how to customize the Home page, have a look at this tutorial: https://www.adaxes.com/help/CustomizeTheHomePage.
No, each time the page is refreshed, the list of managed objects is retrieved from the Adaxes service.
by (2.4k points)
I checked our load balancer settings and added a timeout of 180 seconds.
Now there is no error anymore, but also no groups shown. I have at least access to 10+ groups to manage them.
Is there a difference how Adaxes fetch my managed objects? Will groups managed by another group and I am member of this group be included? Or only groups were my user is set explicit as manager?
We are already running latest version of Adaxes, including Update 3.
Is there any plan to change this in future to increase speed for this objects?
Screenshots: image.png image.png image.png image.png
by (16.3k points)
Please, make sure that the account whose credentials are used to sign in to the Adaxes Web interface has the permissions to view the groups. By permissions here, we mean those that are granted by Adaxes security roles. For details, have a look at the following tutorial: https://www.adaxes.com/help/HideObjectsFromUsers.
Additionally, please, make sure that the Web interface is configured to display the groups in question. The following tutorial should be helpful: https://www.adaxes.com/help/ControlObjectsDisplayedInWebInterface.
The My managed objects content pane always uses the same logic to display objects.
If the currently signed-in user is a member of Group A, and the group is specified in the Managed By property of Group B, the Group B will be displayed in the My managed objects content pane while the Web interface is configured to display the group.
Yes, we have plans to improve the performance of the My managed objects content pane. However, there is no ETA at the moment.
Hi- Is it by design when viewing managed objects via Self Service, it list the user by display name? Can that view be change to include maybe full name? Thanks!
asked Nov 12, 2013 by MeliOnTheJob (1.7k points)
I have a weird issue that I am unable to figure out or replicate to any other user. I have one user who is unable to see his managed objects when he goes to "My ... this user is not seeing his Managed Objects? -Nothing is assigned in Blind User role. Thanks
asked Dec 12, 2012 by jiambor (1.2k points)
Hi everyone, We upgraded to version 2025 on Saturday, and today we've received complaints about the portal's performance being slower than before. Our setup consists of three servers ... Yellow = Server 2 Blue = Server 3 Orange = Domain used, pointing to LB
asked Jun 17 by wintec01 (2.4k points)
How to extend the timeout on the web portal pages, our users on our Hepldesk go call to call to troubleshoot issues, but each time they have to relogin to the portal page each time. Is there a way to extend this time and if so how. Thanks, Tony
asked May 29, 2014 by babbeaw (320 points)
