Trying to manage an O365 tenant and having issues getting the right pre-req's installed:-
Try to install required version of the Azure CmdLets (8362.1) - says I need to install MS Online Service Sign-in Assistant
Install this (version 7.250.4556.0), but Azure CmdLts installer still says its missing.
I can install a later version of the CmdLets - but Adaxes doesn't like that version, so I assume I need a specific version of MSOnline but not sure which one it is?
by (1.6k points)
Have a look at the following help article: http://www.adaxes.com/help/?HowDoI.Perf ... rO365.html.
by (1.6k points)
Thanks - I've seen that, but I'm still having problems.
I download the 8362.1 version as directed - that's OK.
I then follow the link but there is no specific 'Install the Azure AD Module' section - the closest is a link to a download, which I do, but this is ultimately a later version of the above and if I use it I get errors in Adaxes. I can search for and find a specific MSO installer, which I install, but when I then try to install the 8362.1 msi I downloaded in Step 1 it still says MSO is missing.
Can you confirm that 1) I need to install a specific MSOnline installer, 2) the version, and then 3) that I need to install the Azure CmdLets v8362.1?
by (1.6k points)
Note that after trying lots of combinations I have got MSOnline an Azure CmsLets to both install, but when I attempt to access the O365 features in Adaxes I'm getting a "could not load file or assembly" error.
I can manually import MSOnline into a PS session when on the server.
by (50 points)
How are you doing this can you please guide.?
To fix the issue, you need to do the following:
  1. Download the Microsoft Online Services Sign-In Assistant for IT Professionals RTW here and install it.
    Note: Make sure you download from this page. It is odd, but Microsoft has 2 versions of the assistant with exactly the same name, but only this installation works with Office 365 cmdlets...
  2. Download version 8362.1 of the Microsoft Azure Active Directory PowerShell Module here and install it.
  3. Important: Restart Softerra Adaxes Service.
by (1.6k points)
Perfect, many thanks.
by (50 points)
Can you please tell me how you did the manual transfer?
by (1.6k points)
Shamash - I think you may have misunderstood, when I said "I can manually import MSOnline into a PS session when on the server." that was simply that I could start a PS session and successfully load the MSOnline module i.e. Import-Module MSOnline.
by (60 points)
Could you please make this information sticky and/or add to the howto for adding Office 365:
1.Download the Microsoft Online Services Sign-In Assistant for IT Professionals RTW here and install it.
2.Download version 8362.1 of the Microsoft Azure Active Directory PowerShell Module here and install it.
3.Important: Restart Softerra Adaxes Service.
I was banging my head for several days before I found this thread...
Thank you for pointing this out. We will add the information as soon as possible.
Getting error during installation, Softwrra Adaxes 2026.1 Setup - Could not be installed. Verify that you have sufficent privileges to install system service. the service account and ... Nothing in the event viewer that points toward an issue that I can find.
asked Feb 23 by ADuser (180 points)
What is the process if any that adaxes recommends for installing windows updates? Our current setup - 1 - App server - Adaxes console is installed with Adaxes Backend ... . The next update window is approaching and we would like some direction if possible.
asked Jun 9, 2025 by ADuser (180 points)
After installing our second Adaxes service and joining it to the configuration via shared configuration like the install guide said (https://www.adaxes.com/resources/InstNotes. ... ?" I am an administrator and login just fine to our first node.
asked Dec 10, 2019 by mark.it.admin (2.3k points)
After installing Microsoft patches on a Windows Server 2008 R2 server hosting Adaxes 2014.1 we are experiencing the following COMException in the Application event log: An error ... IIS 7.5 Any insight into how to fix this issue is greatly appreciated.
asked Jul 10, 2015 by lgibbens (320 points)
Recently had to rebuild our second Adaxes server, when trying to add a the server back into adaxes domain. The install gets stuck on Instaling AD LDS instance. Getting these ... see anything in the logs from the adadmin1 side. Any ideas what you look at?
asked Aug 7, 2014 by darryl82 (40 points)
