I have made a deprovision custom command. I cannot change the attribute directReports, so was thinking - i could take the people in the directReports field of the manager , and remove the manager in those employees attributes.
Id like the manager to be set to blank, not changed to another manager.
Ive found some scripts that go over all the disabled users, but id like it to only run and change attributes for the manager user (and its subordinates) that im running the deprovision custom command from. Any tips?
by (110 points)
by (17.0k points)
The script in the following repository article does exactly what is required: https://www.adaxes.com/script-repository/remove-direct-reports-from-manager-s5.htm.
asked Feb 19, 2020 by Martin (190 points)
We are trying to do a report on weak passwords, but i dont think adaxes is able to?
asked Mar 16, 2022 by marcwoollard (40 points)
The csv I am using contains firstname,lastname,fullname,pass I will use fullname for both fullname and log on name and pass for the password.
asked Mar 26 by mightycabal (1.2k points)
