I am looking for a way to make the Owners of groups review members in those groups every 6 months and approve\deny the members of said group.
Flow would be something like this,
Report of members of group that you own. > Email the report to the owner>
Email say something like "Please Approve the current members of this group" and then lists out the group members.
Then they have a button to approve or deny the list. If they deny it, it should then ask them which members need to be removed.
Can adaxes do something like that? I was thinking of just making each group re-add all of the group members every six months, which would trigger and approval to owner of the group. So if they didnt approve it, the user would no longer have access.
by (180 points)
Using an approval workflow like you mentioned is the only option. Pay attention that there will be a separate email for each member. Unfortunately, there is no possibility have an email based workflow like the one you described.
by (180 points)
Is there any way to request this feature for a future update to Adaxes?
Thank you for the suggestion. We forwarded it to the corresponding department for consideration.
asked Feb 13, 2024 by wintec01 (2.6k points)
Is there a way to get all Exchange Groups and its members in specific OUs? let´s say the it coordinator of a specific OU wants to get a report of all his exchange groups and ... ! I need this for a scheduled report, but i found nothing. can you help me here?
asked Sep 29, 2020 by m_st (200 points)
Hello dear ADAXES community, what i wanted to do is, to have a custom report which does the following: get every group in a specific OU (the OU comes from an adaxes custom ... Add($Group.name) } } is this possible in such a way? thank you for your help
asked Sep 23, 2020 by m_st (200 points)
This is what I am trying to achieve: Gather a list of all shared mailboxes Check if there are any members and if not send an email to me. Loop through each one and ... schedule say every X months for all mailboxes or X months from when the item was created.
asked Sep 13, 2024 by MikeBeattie (110 points)
