I'm lost as to why "Create User" doesn't show up. I made a new dashboard, mirroring the default Help Desk. Under Actions, I enabled Create User. On the web interface, the option to create a user is not showing. Am I missing a step? image.png
by (390 points)
by (16.7k points)
First of all, make sure to refresh the Web interface page using Ctrl+F5 after saving the changes in the Web interface configurator. Additionally, check whether the Create User action is configured to be visible for the account you are signed-in with. For details, have a look at the Action visibility section of the following tutorial: https://www.adaxes.com/help/ConfigureActionsPane/#action-visibility. Also, make sure that the signed-in account has permissions to create users. By permissions here we mean those that are granted by Adaxes security roles. If the signed-in account does not have permissions to perform certain operations, the corresponding actions will not be displayed in the Web interface. For information on how to grant right to create users, have a look at the following tutorial: https://www.adaxes.com/help/GrantRightsToCreateUsers.
asked Sep 10, 2025 by tromanko (390 points)
asked Mar 20, 2024 by tromanko (390 points)
I would like to show a couple of Adaxes Virtual Attributes in the Web Portal. I've added them in the Configuration, see the 1st screenshot below. I've ... . Any help? Virtual Attributes added Security Role has permissions Virtual Attributes not showing up
asked Jul 29, 2020 by nate2 (90 points)
I created an entry in the AttributeFriendlyNames2.eng.xml file, but the real name still shows instead of the friendly name in both the Web Console as well as the Adaxes ... Others, like this one seem to work fine: Fen-UM-Coversheet FAX Coversheet Any ideas?
asked Jan 5, 2017 by Kikaida (1.1k points)
Hello, We had this happen today, and it is the first time we have noticed this. We created a user using the HelpDesk web interface (our usual procedure), and the user ... seen before, and what we could do to try and troubleshoot if this happens again. Thanks.
asked Nov 8, 2018 by Jasonmh (540 points)
