I was wondering if it is possible to add the enrolment status of a user to the web interface? This is so that the helpdesk analysts can see at a glance the current status of the user when resetting a password and direct them to the self service portal if they are already enrolled.
Kind Regards
Danny
by (200 points)
Hello Danny,
For now, there is no such a possibility out o the box, however you can configure something like this. You can use a certain property of the user account that shows a user's enrollment status. For example, you can use a boolean property, and True means that the account is enrolled. You can also give the property your own name and display it as a checkbox on the Web Interface, so it looks something like this:
If you are OK with such a workaround, we will provide you detailed instructions on how to achieve it.
In the next major version, Adaxes 2017.2, there will be built-in functionality to display the enrollment status in a convenient way.
by (200 points)
Hi, thanks for the response. If there is functionality coming in the next version then we will wait for that instead of implementing a workaround.
Hi, how can I change Help Desk to something a little more specific like "Onboarding Portal"? Or a bit more catchy that our HR will like rather then see Help Desk in the left hand corner.
asked Oct 9, 2019 by 6FigureMission (140 points)
Hi, Is it possible to create a Polish version of Web Adaxes Self Service, or can you give me brief instructions on how to prepare the Polish version? After a brief ... about the messages in the DLL files? I would be grateful for your help. Regards Michael
asked Aug 7, 2012 by MichalMMM (60 points)
After updating from 2020.1 to 2021.1, my IIS keeps throwing a 404 not found error when attempting to access the Web interface configurator. I'm thinking that the path could be wrong or something could be missing?
asked Mar 9, 2021 by blauprgy (20 points)
