Hi
Our users are not exactly pleased with Adaxes Web GUI.
Is there any in this forum who have developed their own GUI and uses Adaxes as engine ?
If so - which development tools did you use - Visual Studio, SAPIEN, Xojo, or something else ?
- Thanks
by (2.6k points)
Could you specify in more detail, what exactly they are not happy with? By the way, currently we are working on a new version of the Web Interface with a completely new look and feel, much friendlier to mobile devices etc. It will be available in the next major release.
by (350 points)
Did you start going in the direction of making your own web interface to work with Adaxes?
by (307k points)
The new version of Adaxes with a totally new Web Interface adapted for mobile devices is available.
You can download the new version here.
Upgrade Instructions
What's New
I am trying to find out how I can prevent a user from being listed as their own manager. I had a case where a user of a supervisor level had their self set as their manager and would like to know if there is a way to prevent this from Adaxes.
asked May 7 by cnew0181 (50 points)
Hi team, is there any plan to add more icons for actions or even an option to upload own images?
asked Sep 11, 2024 by wintec01 (2.4k points)
Hi Is it possible to inject a "just-in-time" text to the "E-Mail notification" Submitted, instead of using the message template or submit our own text otherwise ? The ... in "Operation:" field is too technical to read for most of our approvers. - Thanks
asked Apr 29, 2016 by Boxx.dk (2.6k points)
What are the minimum security role requirements required for vieiwing management history within the Web GUI. I have granted the following to any authenticated users They are ... permissions should be required for allowing viewing this report in the Web GUI.
asked Feb 10 by KoleArmstrong (170 points)
For instance let's say our Ops team has created a role group based on a request from our ticketing software. They would then like to have the creation log on their home page so they can past the info into their ticket.
asked Jul 2, 2024 by ray.edelman (20 points)
